On a 88+ EFI Ford 5.0 engine, if I eliminated all of the smog and emission stuff, where do I route the PCV to? I have a open tube coming off my valve cover oil filler neck and the PCV valve, so where doe the PCV valve connect?
To the manifold at the TB or after the TB?? or not at all?
Somewhere that it has intake manifold vacuum.There should be a vacuum tree on the intake, but if you changed to a carb, then you need to find a large fitting, other than the booster hose fitting, to put it on.
Maybe the back of the carb has a big vacuum fitting at the base?
Do you also apply vacuum to the Breather on the valve cover?
