LBL said:
It is a new build, I have probably only ran it for 30 minutes or so, how long to break in a set of rings? In the mean time, do I just accept that it's going to have wore crankcase pressure and drive it anyways, will it damage seals or anything like that ?
When you say there's "pressure when I pull the pcv valve out of the grommet", do you mean there's pressure blowing out of the valve cover (abnormal if excessive) or that there's vacuum sucking at the end of the PCV valve (normal)?
If the cylinder hone and finish matches the rings and you are using moly rings, they are already broken in by 30 minutes, if things are as they should be. If you have plain cast iron rings, they, too, should be broken in by now, or close to it- but either type will be sealing better after breaking in the engine properly. More
here.
If for some crazy reason chrome rings were used, they can take longer to fully seat, but the chances are slim chrome rings were used.
If the bore finish is wrong- either the crosshatch angle or the 'roughness'- the rings can take from a little longer to break in, to NEVER breaking in. If the rings were installed upside down, the engine will have oil and blowby problems that will never resolve. If the block wasn't rebored, there may be so much taper that the rings can't seal. Details will help.
As far as running it as-is, the main concern will be plugs fouling, oil consumption and detonation from the fuel/air mixture being diluted w/oil. You will need to run it at least long enough to break it in. Beyond that, if the problems don't subside you will be chasing your tail until you go back in and fix the problem(s).
You can use a leak down tester to see if the problem is isolated to one cylinder. A compression test might help to show if there is a bad hole as well.
