428's were FE motors, that is a 385 Series BBFord. 429 or 460, most likely '7!-72 base level 429 with the 2 barrel intake.
If the ID sticker is gone or unreadable on the driver's valvecover, the only way you will know for sure is measure the stroke or pull the oil pan and get the crank casting number.
Block and head casting numbers won't help you, same numbers were used for both 429 and 460 since they share a bore size, just stroke is different.
Good solid 557" stroker build candidate if you can get a good price.
gotcha thanks - picked it up today - 50 bucks and scored an eddie 600 for 10 bucks..
D1VE 6015 AA (block)
D0VE-C (heads)
guess its a generic early 70s truck block?
valve cover says 429, back of block says 460 and under it i6 or L6
Wood Floor Road surface Flooring Bedrock
Automotive tire Road surface Asphalt Grey Font
Water Wood Handwriting Brick Wall
