Hi,
I'm in the middle of building a 1971 scout 2 for my wife's birthday present. (Aug 22nd). I told her she will be able to drive it by then.
I just pulled the oil pan and found the remnants of cam bearing babbits.
I have driven the truck around the block and it runs well, does not smoke and has good oil pressure, no noise from the motor. There is a high pitched squeal from the front of the engine, which I thought was the water pump. Can this squeal be the bearings?
I realize that I will have to pull the engine and rebuild it, but right now I don't have the time to finish before the big day.
Can I put it together and expect to get a couple of hundred miles out of it, or can it go south at any moment and then I'm looking at a major rebuild. I am in a rush to finish it, but not at the expense of destroying the motor. If I can run it as is, I will still rebuild the engine in the near future.
Thanks
Thanks
