Hi everyone,
One of the things I am doing to my truck is replacing the gauge lights with LED's. It is cumbersome to place one, then have to put the cluster back in to verify that I have the positive and negative poles right. Does anyone happen to have a pin out on the cluster where it connects to the dash? I thought that if I could find the positive and negative poles, I could just put power to those outside of the dash itself to test the LED's for correct polarity.
Thought, suggestions?
Thanks, Dan
Moderator
Moving this to Electrical.
The dash connector plugs into the cluster through a flexible printed circuit. The printed circuit has grounds running though it to all of the pin-outs for the gauges and lights. if you trace the copper circuits to all of the lights there is usually a small + or - indicating voltage or ground.
Also if you do a Google on electrical schematics for your truck you will find a ton of them available for free just to download.
Mark
