Ok so...Here's the rub.
Both answers are correct to varying degrees. Its honestly application dependent (or at least it should be). If you're just driving the 'vette around then the bread-n-butter "Equal and Opposite" will get you out of the weeds and most likely be problem free; regardless of coils, leaves.
If you are under heavy acceleration often, then having a different angle at the pinion to compensate for axle housing rotation is pretty commonplace.
Best idea: Tell us a little more about what you've got and (most importantly) what you want it to do. Is the car supposed to look like a D/Gas car, but be street friendly; or, are you wanting to drive a brawler down the street? And pics of a hotrod 59 vette are ALWAYS appreciated.
Good point. I thought my post was too long to begin with, so I left out details.
Engine is 355 cid SBC with Eagle forged crank, Manley H-beam rods, Wiseco 2618 alloy pistons, Strip Dominator with Holley 750 CFM double pumper. Set up to run direct port wet fogger NOS nitrous, but at a later date. cam redlines at 7000.
Super T-10 leading to Ford 9” with Detroit locker.
Stock HB Corvette leaf springs.
I really think the true Traction Masters will handle some of the pinion lift. The car will be a street cruiser with an occasional stop light drag race. We used to have a great drag strip here, but it was recently demolished in the name of progress.
I’ll try to upload photos. But the street photo is old. I haven’t done body work yet.
