Wanted to replace a leaking pinion seal in my Ford 9 inch. Discovered the pinion nut was spot welded to the pinion. Got the nut off, but the last 3/16" of the pinion threads are not good (see the weld in the picture). So what to do:
. cut the bad part off or file it down and hope enough threads remain for pinion nut
. any chance a die would work to cut new threads
. just go right to a new ring and pinion
