Which pistons or rings hold up to the high compression of 305 heads on a 350 best.
I've heard that the stock flats I have will burn through. True or false?
I took apart a 350 motor I bought and it had the 305 heads(untouched)
and 6 out of 8 compression rings were broke in two. I plan on working over the chambers which should relieve some pressure and cut the possibility of detonation.
What pistons would be best? I'm wanting to stick with flats, but I'm open minded. Thanks, Ryan.
