1 - 13 of 13 Posts
I have just one a piston off of ebay,and I'm not sure how to caculate the comp. ratio. J&E sb2 pistons 4.155 bore 927 pin cas ported slight dish .40 deep comp. height 1.342 takes a .043 .034 3.0 ring pack. he didnt list a rod size i hope 6 inch. my heads are afr 215 66cc chambers any info would help
If i m not mistaken you have to run sb2 heads with them pistons as well....
sb2 heads have splayed valves offset kinda like a bbc.....please correct me if i am wrong.....
Your probably right whats the difference in the standard heads? It did say sb2
Crower Roller Lifters SBC Item number: 220039970574
so these won't work with a 1 piece rear main 350 with vortec heads ?
Mustangsaly
King of my Man-cave.
Some SB2 info:
http://www.derrikecope.com/wcup/98/sb2.htm
Pertinent to this thread:
"The biggest differences are in the port layout, valve angle and combustion chamber design. The only things that remain the same are the crankshaft, rods, oil pan and water pump. Other than that, everything has to be changed to accommodate the new cylinder head."
This means the pistons are also specific to the SB2 head/block combo.
tom
Race it, Don't rice it!
Things have changed a little since 1998.
Cup teams can't release part's newer than five years, so anything you buy is at least five year old tech.
1 - 13 of 13 Posts
