I came up with .031 in the hole using a magnetic dial indicator. I will confirm with a straight edge and feeler gauges to be sure.
Thanks
Never mind the feelers. Use the dial indicator to set the piston to TDC, then zero the indicator to the deck. Then measure the pistons at the flat ring like you said. Take your measurements over the wrist pin (3 and 9 o'clock as viewed from along side the engine) to remove the piston rocking in the bore from skewing the measurement.
Those pistons have a dish and they're beveled around the outer edge. This makes taking a depth measurement of the dish and using the diameter of the dish to figure the volume. You can use grease to seal the top ring land and measure the space above the piston to the deck, the same as you would measure a combustion chamber, using a piece of plexiglass or a CD to cover the hole. More on doing this on a budget:
CCing cylinder heads.
Once you have that volume, add the head gasket bore and thickness along w/the cylinder head volume (measure it- published figures are almost always wrong). Then you will know what the static compression ratio REALLY is.
I use this
static compression ratio calculator. Whatever calculator you use, be sure to have the right sign for a dish. Some use a negative number, others a positive number to indicate a dish.
A recent post w/more info:
http://www.hotrodders.com/forum/wan...te-sure-what-i-have-225401-2.html#post1604010
