Piston ring gap
848 Views 21 Replies 12 Participants Last post by  Rustbucket366
Rebuilding my 406 as some of you have probably seen. I need some verification. My ring gap all the way up and down the cylinder is .025. At the very top of the cylinder where the ring ridge is is .016. I was told by a very reputable engine builder that ring gap on a 406 should be anywhere from .024 to .028 on a N/A motor. If that is the case it sounds like I'm good. I'm wondering if that is correct before I finish this engine. What are your opinions?
1 - 20 of 22 Posts
This is telling you the cylinder walls have .009 inch taper top to bottom. By the book this is beyond the range of a worn out wall by almost 2X.
This is appearing as a step rather than gradual taper but this ain’t good. At the absolute minimum this ridge needs to go, the risk is busting rings.
  • Like
Reactions: 1
You misunderstand. They cylinder below the ring ridge is true all the way down. They rings don't go all the way up in the ring ridge.
  • Like
Reactions: 1
The ring ridge is there because it bottom edge is where the rings stop at TDC. The risk is for any reason the top ring exceeds where that ridge starts the ring likely gets busted, that ridge is a hard stop. It really should be removed If you’re that deep in the engine.
  • Like
  • Helpful
Reactions: 2
I don't know any reputable mechanic/ engine builder worth his salt who would re ring an engine with that much west or a ridge left in the cylinder . What does your dial bore gauge tell you about cylinder taper ?
I have called 3 different engine builders and they have all told me similar things as far as ring gap. Their is no bore taper at all. Essentially my whole point of this threat is to ask about what appropriate ring gap would be. Yes their is some ring ridge. Not much maybe .006 difference between ridge and actual surface that ring is on.
I learned this on a Briggs Stratton engine when i was about 12 yrs old. That engine smoked a huge amount after a few minutes with new rings. That was 58 yrs ago..
That and daddy reemed my a** for wasting money.
For a bore of 4.155 inches on a normally aspirated engine not seeing competition driving a gap of .004 inch per inch of bore works out to .01662 inch of gap so .024 is somewhat excessive.
Nothing terribly wrong with that gap amount, it's on the high side but allowances for running it higher performance than stock is common.
"better to be a little to big, nobody will know.....than to be too small, then everybody will know" is an old repeated phrase.
You absolutely have to do something about that ring ridge though, it has to be removed or it will quicky kill the new set of rings because the new set will be a few thousandths of an inch thicker compared to the worn thinner originals that made that ridge....comprende?
Plus if you turn more rpms than the typical rpm that created that ridge the parts stretch and flex that comes from running a higher rpm hammers the new rings against that ridge even harder.
  • Like
Reactions: 1
Yea I understand. I decided to take it to the machine shop and let them take care of it. 600$ is not too bad
  • Like
Reactions: 4
Ring Gap. 4 thohsand of a inch for each inch of clynder bore, I would check a shop manual,if not advable use the 4 tho.per inch, Tom
My forged diamond pistons (4032) calls for 0.0045 per inch for naturally asperated. I would purchase rings that require gapping and you can get it right. 0.024 to 0.028 sounds like power adder gaps.
That's crazy because the machinist I took it too said that gap was about right for a 406 sbc. Also about 3 other machinist told me similar things. And also the KB piston head formula tells me that I want about .024 piston ring gap on a stock application. That's the hard part about these sites you get 50 thousand different answers.
Ring gaps don't matter much.
Put your top ring at .021-.023, that is .005/inch of cylinder diameter.
Make the second ring Gap at least that much or bigger.
Surface finish of the cylinders, roundness of the cylinders, and the thickness of the cylinders are the primary factors in good ring seal.
  • Like
Reactions: 1
3
This info came with my file to fit Total Seal piston rings. I would recommend checking with the piston manufacturer and the ring manufacturer for the gaps.
There literature even says to check with the piston manufacturer.
See less See more
You see, this is new info into the mix.
The KB piston, if this is their hypereutectic piston, is different than almost everyone else.
Their design with the ring pack moved closer to the top of the piston makes the rings run hotter and requires bigger than standard gaps because it is going to close up more from heat expansion.
Are you using a KB hyper piston??
  • Like
Reactions: 1
Yeah while the hyper pistons don’t expand as much as non hyper whether cast or forged the ring rides higher thus hotter in these pistons. So without regard to piston expansion that top ring is running hotter.
The other consideration is how you intend to use the engine where leaning on it a lot causes there top ends to run hotter thus more ring expansion. Kind of funny in the good old days of the 1950/60’s the manufacturers oil called and lubricated the pistons with an index spray off tge big end of the rod. That all went away by the mid 70’s but here we are with it returning in the 2000’s. Now their using a fixed device but the result is the same of cooling the underside of the piston and wetting the cylinder walls.
For mild street driving .024 is probably a bit wide simply besause legal street driving isn’t heating the rings enough to get to a by the book running clearance.The only downside is a bit more blowby. One the other side of the coin if you run the by the book ring clearance while using a heavy foot on the gas pedal or leaning into the power adder of choice the by the book end gap is likely to use up all the available space while needing more, when that happens things get mechanically ugly mighty fast.
So the opinions you get for .016 plus a cosh or .024 is contingent on how the motor gets used or abused and how much risk of the latter happening is involved.
The good, bad and ugly with high silicon pistons is they hang together until they don’t, you don’t receive input on their impending failure their there one moment and not the next, whether this is a cast hypereutectic or a 4032 forging. On the other side of the silicon divide plain old cast aluminum pistons tend to develop holes and gaps but are inclined to stay the course where 2618 forgings make sounds of protest before all is lost. Rather like silicon enhanced ladies are hard to hang on to, there one day gone the next while those with the natural product tend to complain a lot but hang in there.
At least that’s my experience, yours may vary
See less See more
Interesting analogy... :unsure:😂
You are encountering some differing views on this topic. You might be OK and you might be getting some wise counsel. Of course it is your choice. For example if you are using used pistons, you likely have some ring land wear and may be fine. If on the other hand you are using new pistons along with new bearings, you just might be pushing those piston rings a wee bit higher in the cylinder and those new rings might be hitting that ridge. If that is the case and you are using cast iron rings, not chrome moly, you may well break a ring. Of course the decision is yours 100%. I have heard the advice you received from my first engine rebuild in 1965. I have done it both ways and have yet to have an issue. I think you have a decent chance of it working. That said you can also remove the ridge fairly easily with a ridge reamer. In either case your engine will likely run just fine. Your original question on end gaps sounds just fine.
1 - 20 of 22 Posts
