1 - 18 of 18 Posts
The piston rings in my 1968 Chevy step-side have stuck, I have been told that I could take my spark plugs out spray pb blaster in each plug hole and turn it over and it would un-stick them but I do not want to try this without being sure.
I went out and turned it over it turned over just fine 4-5 times then it wouldn't turn at all. So I myself am assuming that's what it is because it has indeed been sitting for a while and I checked the oil it was just barely on the end of the dipstick so i'd say the carbon build up has them stuck. May be wrong.
No offense intended sir, but I was just asking a simple question and there is no reason to act that way. It has been sitting for 10 years, it was my grandfathers and he gave it to me I just started messing with it last week and in that time I have rebuilt my q-jet carb put a full tune up on it put oil in it and I am only 16 so I was just asking because I am indeed inexperienced with certain things on vehicles but I know what i'm doing. I was thinking about just rebuilding the engine for I have motor lifts and all that I need to disconnect my tranny, unhook the radiator and take it out but I was just wanting to know if there was a more simple way of doing it, I know what to do and how to do it I was just wanting a more professional opinion first.
big,what engine is it?try taking out the plugs and turning it over by hand.did you put any oil down the bores? Did the engine run well when it was parked? any info will help get you started
Settle down no harm was meant. Just my way of passing on ideas. Humor usually breaks the ice and you can tell alot from the response.
V, is right can you turn it by hand?
Discussion Starter · #8 ·
It has a 350 4 bolt main on it and it has been bored out and has a cam on it and yes it ran like a top when it was parked back when, it will not turn by hand, and no I have not put any oil down the bores
What will cause it to not turn over by hand plugs out...hmmm. You tuned it too, that usually means it was running fine. You filled it with oil and now it barrely has any. You can run a engine with the level touching the dipstick. Did the starter soleniod leave the bendix gear engauged in the flywhl.
Discussion Starter · #12 ·
No it didnt so I have no clue what's going on it went way over my head, I think it may just be time for a rebuild being that it is an older model and has been sitting for a while but it only has 75,000 miles it isn't the original engine but it came out of a 68 camaro
Banned
so it was just turning over fine and stopped? It doesn't have a thing to do with piston rings.
I would take a 1/2" ratchet and turn it over by hand, in either direction. Since it sat for a while you MAY have something that fell in the intake manifold and got sucked into the cylinder during cranking. Anything from a old crusty mouse to a stray nut or bolt could do it.
Read this end to end, it's probably dry, the cylinder bores, pistons, and rings if it was turning then suddenly wouldn't. That's not to say other dastardly things couldn't go wrong after setting for 10 years but let’s start simple.
There is no down side to spraying a penetrating oil into the cylinders from the spark plug holes other than if you get it started it will smoke a lot for quite a while, actually. Keep in mind that getting anything like an even coating on the bores is hard to do if not impossible but do your best to get the spray around the bore without losing the straw into the engine.
WD40, PJ1, Marvel Mystery, Free All, CRC, etc, whatever is in your neighborhood stores will work.
You could hydraulically lock the engine with too much oil in any one cylinder to where there's more oil than compression volume, but turning the engine with a wrench such a condition would just stop you, it wouldn't result in damage, different story if it's being spun with the starter motor. But that amount of oil especially from a spray can is a lot of oil, you should notice this. So just go easy, take your time. Let it set awhile, maybe over night, to give the oil a chance to flow out. Capillary action over a time period will actually let this stuff move against the forces of gravity into the higher bore sides.
If the starter turned it over and stopped, look at the starter gear. It is probably locked up the flywheel/flexplate.
If you take the starter out and it still will not turn. DO not STrong arm it. BE smart. Use a 2' extension pipe on the handle and rock back and forth with penetrant down the plug holes. Use the leverage and gently add torque to turn. You are not in danger of breaking the rings.
1 - 18 of 18 Posts
