Hello everyone! I recently stumbled upon what I believe to be a Ford Flathead motor. It has been sitting on grandparents property for years and where I have just moved to. Having difficulty identifying as this teallly is not my thing. Any help and value would be appreciated. Thank you
Discussion Starter #3
I tried posting on Fordbarn and for some reason it will not allow me to do so. O did count the bolts if that helps any and there are 21! Lol
Ford put the water pumps on the cylinder heads until 1936. It would have 21 cylinder head studs and be 221 cu in. I can tell you it is between 1932 and 1936 but I am not good enough to tell you more.
My expectations are that it is worthless if it has been in the weather. The blocks are very prone to cracking if frozen and it appears that motor has had ample opportunity for water to ge in it.
Interestng find though.
John
