Hello guys I have another question here and I read somewhere before someone doing this and can't find anything doing different google searches. I have a 600 Holley vacuum secondary I am working on and it had an electric choke on it and I am putting a manual choke on it and I know when doing the kits they give a lead ball to stick into the vacuum hole to close it up so as to not have a vacuum leak since your not going to be using an electric choke.
I am going to a manual choke on this but I don't want to take away the ability of being able to use an electric choke in the future in case if it ends up in someone else's hands then I want to be able to put it back as an electric choke if wanted. My thing is I don't like using the sticky cardboard cover that comes in the rebuild kits as over time I have seen them fall off and cause a hidden vacuum leak that is hard to find at first.
I don't want to stick the lead ball in there and I have heard of folks tapping it with threads and putting an allen cup screw into it to seal it up instead. My question is what size would I be able to tap that hole and has anyone done this before as I have a tap set and a drill bit gauge set to do everything with. I tried like I did before and used some RTV gasket maker over the hole but its the JB weld brand this time and for some reason sitting in my house at room temperature for 24 hours it did not fully cure and was still soft underneath and only cured over the top but not the bottom. I was able to take my paper towel and wipe it off with very little force.
I need to get this thing running by this weekend so I have my wheels going again as I just cleaned out my carb and put some new gaskets on it and took my electric choke off of it to go manual which is what I recently had on the previous carb that was on it but it was sold to a gentlemen who needed one for his ride. I used gasket maker on it but it might have been a different brand but I don't know as it worked. I just want to be able to keep it being able to go either way and not permanently take away the electric choke option.
Tapping it for threads and being able to use an allen cup screw would be excellent and I could then take it back out if ever going electric again. Hope to hear from someone who has maybe done this mod before and give advice on what thread size would work without having to drill the hole if I don't need to and just tap it with the size it already is Just looking for a better way to seal up that hole with it still being able to be used as a manual or an electric choke.
Thanks everyone.
Thanks everyone.
