byrddogg65 said:
Hello all. I have a rebuilt 400 sbc it runs but the # 2 and # 3 cylinders will not fire. I have changed plugs and wires adjusted carb and timing. The valves are adjusted correctly and working properly. The firing order is correct. Still those 2 cylinders do not fire. I was thinking maybe a vacuum leak, but would this not cause misfires on all cylinders? Any help or thoughts will be helpful. Thanks Jason.
When you say "will not fire", do you mean that there is no spark at those two plugs or that there is spark but no fuel mixture ignition?
1. If it is a fuel mixture ignition problem, it could be a valve issue on those two cylinders. If the valves are not sealing, during the compression stroke, the fuel is pushed out past the valves and not igniting. You need to perform a compression test on those two cylinders. Without compression, there will be little to no combustion.
2. If there is no spark at those two cylinders and you have changed plugs and wires, check the distributor cap.
Just need more info in order to help better.
