1 - 14 of 14 Posts
Save your money and buy a kit to remove the points.
Why have such a old system in your car? Pertronix has kits that fit right into the distributer like the points but are all electronic. (There are other companies out there that is just one of them.)
The best part of those kits is that you set them once and can forget about it. You will not have to question the condition or the setting of your points again!
I think they run about $100.
Tim
Good idea but I don't want to spend any money on the 6 banger unless I have to. Plan on dropping in a small block in the next 6 months. 130 hp doesn't quite cut the interstate with a 5000 lb vehicle.
Premium Member
Considering I had to reset my dual points every 3 months to maintain peak performance I would never put another set into a car when electronic alternatives exist that cost less than a meter to read point dwell.
Unless you are restoring I would get an electronic alternative like Pertronics.
Premium Member
Yeah my friend and I went through this problem with his 68 327 vette. Thing always ran like crap, so we picked up all the equipment to adjust it from murrays. The guy was like "there are cars that still have points?!"
it ran ok if you had it adjusted properly. It was, admitedly, a bit inconsistant.
He's since ditched the kit for MSD. I don't think he likes that much either (MSD isn't really as great as its made out to be).
Mallory makes some quality ignition stuff-
K
some people just don't like anything they don't understand, hence wanting to stay with points. 10 years ago a friend of mine wanted to convert his 4cyl Nissan from electronic ignition to points ignition, because he feared of not knowing what to do if the electronic system failed on the road. Most ignition modules are now cheap enough to buy one to keep as a spare in your glovebox. Even you don't understand how to diagnose a faulty system, anyone can at least replace a module as a process of elimination - specially as modules are usually the first component to fail.
Discussion Starter · #12 ·
I discovered why I was a bit confused. My distro does not have the slot to adjust the dwell. The points don't have the dwell adjust either. All it has is the screw to adjust the gap and the screw to tighten the same. Also discovered a vacuum hose loose. This was screwing up everything. Tomorrow I'll set the timing.
Discussion Starter · #13 ·
Follow up.
I set the points to 016 and treaked the carb. I also tightened the top of the carb. When I was adjusting the carb screw suddenly the skip went away. Now it idles smoothly at low rpm's.
Thanks for all the help guys.
Marcel
hey Doc
The old tail was that that capsule that can with the points was for the headache, caused by the points. I had a friend who did it. It helped his bowl movement, don't know about the headache.
1 - 14 of 14 Posts
