Okay I'm back online. Thanks for the historic background and contemporary status of the Muncie system. Gulp. That's a lot to digest but I'm learning a lot from your posts. I believe Muncie=good for this project. I want to meet up with one of your retailers in Texas to see the parts and figure it out in real time. In the meantime your offer to send a measured drawing of the two spline configurations might help me figure out the shifter issues. How can I get that drawing? A pdf would be fine, or whatever you have. I can dump it into CAD one way or another and go to work.I'd call Larry at Wells Speed in Weatherford TX. Theres also 'Kajun' Jon Bergeron in Whitney, TX.
I can send you a measured drawing of both versions of the aftermarket 'Muncie' (10/27 spline and 26/32 spline)
An aftermarket Muncie with the Euroricambi gearset and a 26 spline input is perfectly happy behind a 502/502 ZZ502 BBC. If you are going to get rough with it, I'd go 32 spline output, shifter handle be damned. If you want to try and run with the big dogs, an M23 takes up where the M22-based stuff leaves off. An M22-based, italian gearset, aftermarket 'Muncie', with the roller sidecover, iron midplate, Supercase, Super Tailhousing and 26 spline input and 27 spline output weighs about 85 pounds dry and takes 1-qt of 75w90 non-synth GL4.
In an earlier post you mentioned what you thought would be a good rear gear and tranny combination. It was a streetable 3.23 rear end and a 2.98 first gear. Is this option part of the modular system you mention? I'm still trying to square the gear combinations with the M22 system. I'm understanding with the M22 (Italian) gears which have a more consistent strength and a shallower pitch I can assemble a 2.98 1st gear and a couple different second gear options to run with a 3.23 rear gear. This could be in a stock case or a super case. If I go with the super case and the cast iron midplate the overall assembled length increases by 0.147" due to the thickness of the case. I'm not sure if the modular gear set (assuming that's what we're talking about here) dictates the 27 or 32 spline output, or if either is still an option. If I go with the 27 spline output the D/S will be longer than if I use a 32 spline output by 0.700". In other words the tranny assembly gets longer by 0.700". No big deal as I have no D/S yet. You also recommend a 27 spline mainshaft. You said this gives me two options for the shifter. This is where it gets confusing to me. I'm sure it will be clearer when I see some parts. I don't understand how this affords me 0.700" more or less dimension for the shifter location. Somehow the 32 spline output is dictating the shifter mounting points even though we're well behind the shifter at this point. I'll figure it out. It's just geometry.
Hey thanks again for all this useful information. I look forward to getting started!
