Hi everyone. I'm a newbie here and have a question. I've been working on restoring the front end of my 85 Tojan Trans Am. I took apart the entire car forward of the firewall. I've been working on sandblasting everything and I'm about done. The paint was crappy and I had several spots with light to medium rust. The sand blasting has taken forever do to school and other problem. I've got a little bit of surface rust again in a couple of spots although I can hit those spots again.
My question is should I use por15 (this is what I had planned to do) or should I get some epoxy primer. I plan to paint the engine bay with dupont chromabase jet black and chromapremeire clear. I know if i use the por15 I need to use the tie coat primer. I already have the por15 and the tie coat but i'm double checking before I start. Thanks for the help, josh
