Any one have any thought on using Pore15 as a primer? Is it as tough as 'THEY' say it is? I am thinking about using it as a prime under a urethane coating inside of the trunk up the fire wall and floor pans.
i have use por 15 and it ok, after two years it flaked off and break fluid eats it right now!!! i used something new to me its called rust bullet and i put it on my bare metal after i did patches because i knew it would be some time befor i got back to it. well about 3 months later when i was using a chemical stripper on my body the parts with rust bullet did not strip off very well. i ended up sanding off those spots, the stripper worked great with the factory paint. good luck jason
SPI Thug
none of it works. all it will do is hide the rust for a while.
