i just got done with my built motor about two hundered miles ago. the first fifty miles or so i didn't have pvc valves in the valve covers and i noticed that there would be like a oilly smog coming out from both of them, (factory vortec covers) so i went and got two of the correct pvc valves for the year motor (98 vortec 350) and plugged those in and some cheap APC breather filters from the ricer section. worked fine, i thought. i'm driving the car down to the range and i see a white cloud behind me so i shut it down and checked under the hood, oil spurting onto the header from the dipstick tube, given the stick doesn't fit right to make a great seal, i dont think it should be coming up like that. i checked compression hot and it was 165 +-3psi across the board so i dont think its rings, i'm guessing the filters got saturated with oil and built up the pressure. but how should i correct this problem?
motor is a 10.5-1 vortec 350, hr282xr comp cam, air gap, holley 650 dp. 15* initial, 13* vac, 21* mech.
(ps i would like to thank you all for helping me build a car that scares the **** out of me.) '84rx7, 420ish hp, 460ish trq t-5.
