Hello guys I am making a new post here and some who have followed my other posts have known I am having carb related issues of things not wanting to work right like they should and also a bad studdering when letting off the throttle below 2000 rpm and things running very lean at times and adjusting my carb is not getting rid of things and erratic idle and off idle issues etc.
Ok on the video below the guy goes into details on checking for internal vacuum leaks. I left my pcv valve hooked up at first and took out my valve cover breather on the other side which is external and pictured below and took out the grommet to it and put in one of 3/4 ID size so I can hook up my vacuum gauge and see what is going on. I am getting conflicted things here.
In the video the guy plugs off the pcv valve or unhooks it and plugs it off and then hooks up his vacuum gauge on the port on the valve cover. He gets a vacuum reading and he states you should have pressure and not vacuum.
I am assuming he has the breather aka filter port plugged and then puts his vacuum gauge into the one valve cover port and he gets vacuum reading. I did the same exact way he did. I plugged off my pcv valve side and after doing that on the driver side it will slowly build up pressure. If doing the opposite it does the same thing. Plug off the driver side and hook up vacuum gauge to the passenger valve cover port it slowly builds up pressure.
Now if I hook up my pcv valve then the driver side where crankcase vapors should be coming out is then having a big vacuum sucking up through the breather port and if putting in my vacuum gauge it will go over ten plus inches of vacuum.
I know that last part is not the part of the test but is there anything going on here that is wrong? I have never had to check for an internal vacuum leak before but am just trying to throw all things out. With my pcv valve hooked up and it creating the huge vacuum on the other side to be pulled after its hooked up would indicate to me something is wrong as if I understand correctly even with the pcv valve hooked up the passenger side breather should be expelling crankcase vapors and it should be flowing to atmosphere and not sucking in, or am I wrong?
In the past with my pcv valve hooked up and stuff from memory I always had an open air filter on the driver side and previous one had an attachment to hook up a hose to your air filter element and I could swear I saw vapors blowing out of it if I remember correctly. I might be wrong.
But with out pcv valve hooked up and one side blocked it slowly creates pressure on the valve cover port regardless of plugging one side and putting vacuum gauge on the other and when the pcv valve is hooked up to the carb like normal it then creates a vacuum pulling in on the other side and will do it either way just like checking for internal vacuum leak.
Now how the pcv valve system works is should the one side be used for sucking in crankcase vapors and the other side should be expelling blow by vapors and it breath to the atmosphere as I have seen in the past or am I wrong there? Sorry guys for the post but hope you can help me out here. With the one port plugged and the other left open the engine will start up way better and does not shake and rattle and roll as bad and is smoother.
Once you hook up the pcv valve the engine shakes and studders really bad but beyond that I have to have the throttle way open past the transfer slot just to keep it running enough and thus my mixture screws don't adjust too well and is running rich for time being. Have not messed with anything else until I have confirmation that I have an internal vacuum leak going on.
Just trying to trouble shoot and eliminate potential problems and find the source of my issues.
Thanks guys and appreciate it.
