1 - 10 of 10 Posts
what are some easy...but affordable ways to give youre old stocker 305-350 more power!?!
its sooo slow please help!!:pain:
kyle
Power
Vortec Heads and a SMALL camshaft...not a lump da lump cam...Just a nice RV or towing camshaft. Oh what sucks is you gotta have a different intake for these heads.
Jim Pace Performance.... http://www.paceparts.com/
Premium Member
Wouldn't he want shorter gears?
Nitrous is probably the cheapest but can be dangerous if done incorrectly.
Cam and heads are where the power is at. Like was said, get a small cam (duration wise) that will give you some nice low end torque. You can make some good power however you are somewhat limited as its a 305 . . . a fairly small displacement motor.
Tazz
305 or 350 which is it? They are not the same and will make power according to what modifications you make to them. Go to the right front of the engine behind the altinator for the flat plate with the stamped numbers on it and write down the numbers and look them up and see what motor you have to begin with.
Tazz
Rat Rods Rule!
Footbraker
If it has a Y-pipe and single exhaust, headers and duals will make a noticeable difference.
More power
If it's a 305 you can just about by a GM performance crate motor for what it takes to make them run strong.
Like tazz said is it a 305 or a 350? 2bbl or 4bbl?
Acctually it was 305-350 not 305 and 350, that includes 305,307,327,350 i think he was refering to small block chevys in general. rebuild it with low compresion pistons and pop a blower, headers, hei distributor, rebuilt heads, new exhaust system, just take it somewhere hand them a huge wad of cash and ask them to make it fast!!!
Discussion Starter #10
yeah thanks for the help it is a 305 with a 2bbl but i was reffering to all chevy small blocks 305-350
thanks for the help
1 - 10 of 10 Posts
