1969 Mustang Coupe Project Car
Hi All:
I have a power steering pump I purchased rebuilt a while ago. The rebuilt pump is slightly different since it looks to be the type used in a Mach 1 instead of a regular Mustang. The Mach 1's had a cooler that ran on the return line thus the tube on the pump bends up instead of down. Since this is the return line I believe it should be low pressure.
I bending the hose 180 degrees isn't an option. So I was thinking I have come nickle copper 3/8 line could a just make a u shaped piece and hose clamp that inline to change the angle? Or is there a better option since finding a new power steering pump cooler is pretty rare.
Thanks
Mark
Race it, Don't rice it!
That would most likely be just fine.
The next best option would be AN hose and adapters but that's also a chuck of change.
Thanks Johnsongrass1
I like that idea, in face I remember seeing a barb 180 with a AN on the other side. Then a barb fitting on the other end. Yeah I like that idea a lot. it will look cleaner too.
Thanks
Mark
