1 - 8 of 8 Posts
two cups of tea
ok fellas so this is the deal lately I've been working on my dd its a lifted 2nd gen ram&well I had a few leaks the cad was leaking as well as the ps pump.Well I usually Always work on my own stuff this is only the 2nd time I've had anything worked [email protected] shop.Well I go to pick it up&the pump is squealing...I tell em they say it should go away there was some grease that got on the belt.
Well I go home&clean everything up&a couple hours later I go&looks&the pump is leaking in the same place.Then I hop in the truck to take it back to shop&ps goes out...take it back&they tell me my gear box is bad that its too sloppy,I then tell em it seems fine to me Ill adjust it when I get home&he tells me there is no adjustment.Well since I've done it before...anyways he then says I shouldn't of worked on no damn lifted truck.Calls me back next day&I pick it up&I get home pump is squealing when I turn wheels...no fluid!Maybe a tea spoons worth.Fill it up...still squealing take ot back&gets all cussing&saying he's just gonna re fund it&put the old pump back on.Then today he says couldnt find old pump...no refund put another pump back on&5 minutes later started making the same noise.
I belive they didn't swap it the last time.I put a stethascope to pump&the sound is coming from there not the box or anywhere else.Are these guys just crooks&I keep getting bad pumps?Because Ive went over&over it in my head&there's noway the steering box could be causing pumps to blow in 5 minutes or anything else&there's no metal in the pump.I'm willing to bet they didn't bleed the system.The only reason I even took it there is because I didn't have the time& hate leaks with a passion!Under carriage has to be homer dry or I don't drive!Only thing should be even close to wet is my grease fitting should be greassey&ax cons dripping
Sounds like you have a valving problem in your box , most likely causing a hydrolock situation and stressing the pump.
Replace the box and the pump at the same time. I wouldnt go to the shop you were at.
Check around, find a competent shop.
two cups of tea
to be honest I don't think they really replaced all 3 they were being real jerks from the get go cussing about I shouldn't of worked on the mother f n truck this is some b.s. etc...ok so my first pump was leaking from the fitting where the pressure hose goes into it.For all I know it only needed tighting up my mistake for not checking..but yup it didn't make a [email protected] they said ps pump is leaking needs replaced so I said go ahead,picked it up&as soon as I started it it was squealing so it had only moved from the bay to outside.So it dosnt seem long enough to do nothing.When I came back after all there bs they replaced it.
When I brought it back yesterday they said bad pump&all that I already said.But this is the reason I don't think they replaced it.I heard the guy tell the owner no not the first one but yeah the second one was under warranty...that seemed sketch since I payed for the one with warranty then I drove past the shop tons today truck never moved&now there saying they couldn't find other pump&the 3rd went bad.Well the agremment was to get the old one put it back on&pay me back.I think they couldn't get the old one back&just left the. bad one on.
WFO
Did you get a refund and a pump that is at least as good or bad as the one you started out with? In other words, are you back to how you were before going there, except for your lost time and aggravation? If so, consider it a learning experience.
Have you turned the wheels from lock to lock w/the wheels off the ground to bleed the pump? If the pump is still noisy (and the noise isn't because the fluid is too low from the leak) replace the pump.
Check the high pressure hose where it connects to the pump carefully to be sure the hose, flare or the fitting isn't bad.
two cups of tea
nope they won't give me my money back,&there's a worse pump on there then I had before.
1 - 8 of 8 Posts
