As I posted in my introduction Greetings from North Georgia. "Hot Rodding" a...
I'm dealing now with a Chevrolet Straight 6 250CID engine. I'm not sure what it's from, probably a Nova or a Camaro from the late 1970s. Sometime in the 1980s, this engine was swapped into an early 1960's British Limousine. The big issue with this setup is that it's underpowered. I'm not sure if it's just too much car for too little engine, or if the engine is well below it's potential. I suspect the latter, or more likely a combination of the two.
We're now considering upgrades to increase power. I'm looking for advice here, especially from those familiar with this line of engines.
Things we're considering:
Upgraded Intake manifold and Carb (or upgrade to TBI).
I'm pretty sure the carb isn't up to much more than stock power. I'm prepared if someone wants to show me I'm wrong, but I'm guessing a larger carb is in order.
The only alternate intake manifolds I see available right now are for square bore 4 barrel carbs. That with a small carburetor (maybe a Holley 390cfm unit) might not be too much carburetor if other upgrades are made. Or can I run a 350CFM 2 barrel on that manifold with a spacer/adapter?
I think a TBI unit (either aftermarket or something pulled from an early 1990's truck with the 4.3L V6 or 5.0L V8) could also work with that manifold, and might be worthwhile. That should have fewer issues with ethanol blended fuels, but it will require an electric fuel pump, etc. etc. More costly and more labor intensive than just a new carburetor, but probably more fuel efficient and reliable as well.
Upgrading the cam:
I guess the first question is, do I have a damaged/worn cam now? I need to pull the valve covers and put the dial indicator on the pushrod end of the rocker arms and see what the lift is now, and if it's consistent across all cylinders.
If cam replacement is needed, I see there are numerous choices. Would something in the 260-270 degree (advertised, probably 210-220 degrees +/- at 0.050" lift) be appropriate for this engine? I want something that will still idle pretty smoothly, but give some grunt and power. What we used to call the "RV Cam" is what I'm thinking. If I'm going to the trouble of a new camshaft, I'll definitely want to do an upgrade there, not a "stock grind" replacement.
Upgrading the exhaust:
It currently has the original cast iron exhaust manifold into a single exhaust pipe. The pipe looks decent (maybe 2.5" OD? I'll have to measure), but the manifold looks very restrictive.
I see there are header pairs available for this engine that split the front cylinders from the back and could be used with a dual exhaust system for better flow. I'm thinking headers + X pipe + resonators + dual in, one larger out chambered muffler (and maybe even a third resonator aft of the muffler) as an alternative to the full single system that's there now. I'll need something that's both free flowing and quiet. The good news is, with nearly 12 feet of wheelbase and some overhang at the rear for the trunk, I've got room for lots of exhaust goodies to quiet the thing down.
Other than an engine swap, or forced induction, am I missing anything?
Assuming a well executed plan here, what kind of HP and Torque numbers is this thing capable of? Anything close to (or over) 200HP at the crank with 200+ ft. lb. of torque (numbers in the ballpark of the 4.3L Vortec V6)?
Oh, and this thing has a TH350 transmission and some pretty short gears in it (3.90 or 4.10/4.11 if I had to guess). There's a Ford rear axle in the back now. That part of the power train seems pretty well sorted out. The only thing I think it might need, depending on the engine setup and torque curve, might be a mildly higher stall torque converter.
Upgrading the cam:
