I have been researching this quite a bit, but have not found answers to all my questions so I thought I would ask here since this forum came up quite a lot and has helped me a ton already.
I am building a Powerglide for a 66 caprice. Swapping a mild 400 Horse 489 into it. I want to make the trans reliable. So I can drive the car without having to worry that it might blow up if I step on it. Have bought the Glide Bible, which is on the way as well as some parts. Namely a steel high gear hub and a new input shaft.
Now as for the clutches. I want to upgrade the high clutch pack from the 4 disks. I have heard conflicting things about the OEM drums. Are there different OEM drums? Can I fit 5 or 6 friction discs into the standard 4 clutch drum by just throwing the wavy washer out without having to turn down the piston?
The reverse clutch had me kinda confused as well. The pack I pulled out of there had 6 friction disks in there. Is that normal? Every bit I read talked about 5 frictions.
Thanks in Advance
-Tim
Thanks in Advance
-Tim
