65 Impala Ss 283 4brl:
I Pulled Out The Powerglide And Put In The Saginaw 4 Sp From A 66 Impa Ss.
Can Aanyone Recomend A Good Rear End Ratio For The 4 Sp Street Use? Power Gride Ratio To Low.
I would use a 3.08 gear for the street
Any idea what low gear ratio is in the trans? If it's 2.54 like I suspect it is, I'd use mid to high 3's. It might be easier to look for a Sag with a higher low gear ratio and swap it in. It'll be much easier to get moving from a dead stop, and you won't have to slip the clutch so much. I went from 2.54 to 3.11 in a Nova with 3.08's and a 350, and it was like driving a whole 'nother car. Clutch life was more than doubled.
Available ratios and ID info are at www.dandltransmission.com/saginaw.html
