Hi, I recently just bought a 1971 400 2 bolt main Small block chevy, its a complete virgin block. Sad part about the motor is that it has sat for about 3 years, and has taken a beating from kansas weather. Its froze, but the rust is not deep. A hone could easily take out the rust inside of the cylinders. The motor was tooken out of the truck due to a broken piston and just sat and sat. I recently just got a Job at a Nursing home, as a maintennaince worker, and Im kind of just pre planning the build completely. The motor will be rebuilt fairly stock, and Ill just do add ons until I reach my goal. I want the truck to be leaning towards the drag strip, yet still be fairly streetable.
Basic Plan- The vehicle that the motor will be placed in is a a 1986 s10, that weighs 3200lbs empty. Im looking to get around 450-500 horsepower at the motor and hopefully around 375-400 at the wheel. The tranny for the vehicle will be a TH 700r4 with a stall around 3000-4000, servoed out, and the differential gearing will be 4.10s.
Im thinking to hit around my goal, that this setup might be in the ballpark.
406 (.03 over 400), a 750 cfm Holley Double pumper. Im not sure of the intake, but Im thinking something around the 2500-6500 rpm range, Maybe a World Motown Intake that makes power from 2500-8500. A summit Capacitive Discharge Ignition Box with a rev limiter set at 6200 RPM. Dart Heads with 215cc Intake 64cc Chamber, 2.08 Intake, 1.8 exhaust. A Comp Cam, 2500-6500 .248/.248 Lift .525/.525. And a set of S10 shorty headers, with 1 1/2 inch primaries. Summit 1.6 Roller rockers. Stock bottom end for now, until I get enough money for all Forged. And a set of Drag radials, ttraction bars, just basic things to get some traction.
Do you think this could do high 13s on the 1/4 track ?. WIth 106octane, and a 100hp shot of NOS ?.
Anyt tips or advice is greatly aprreciated. Thanks
