So I did a little research and couldn’t come up with exactly what I was looking for, I plan on stripping the car to bare metal, epoxy primer, body filler, 2k primer, bc/cc in an almost royal blue (I don’t have the paint code at work with me). I have been told that you want your primer that’s just under your basecoat to be as close as possible to your basecoat color, so in my case this would be black, I was hoping to do my epoxy primer in black because I was thinking it would be easier to see the imperfections that I am trying to fix, I’m new to bodywork so I’m wondering what you guys are doing to make it easier to see those imperfections, I’m assuming I don’t want to spray black epoxy and then try to spray black 2k on top of that?
Another question is that I have been told to spray epoxy primer and then do body filler over the epoxy, can I also do body filler first and then epoxy, or will there be issues with the epoxy sticking to the filler? This question is a bit vague without all the details but for a rough guestimate, how many gallons of epoxy primer would I need to cover all body panels, the interior, and the underside of a 72 Nova? The primer I will be using is a 2 part 1:1. Again sorry if I’m a bit vague on this as I haven’t done much bodywork, I do plan on doing a lot of practice on spare panels I have laying around before I attempt to tackle my car.
