1 - 9 of 9 Posts
two cups of tea
Ok so Friday I was getting ready to spray when I went to go warm shop up no heat..well got heat today&ready to shoot this is the deal I had just got done block sanding the primer.Since its sat over the weekend what do I need to do now to the primer before I paint?
Did you read the data sheet for the primer you used? One primer I use says it can be recoated up to one week, but it is not the Summit primer.
The data sheet will tell you the recoat window for the primer you used.
two cups of tea
Yeah I just read it says that after 18 hours it has to be abraided..so Ill do that tomorrow..I uad only hit it with a 1000..before I used 320 but the 1000 seemed to work just had to work a bit harder.Ill go ahead&hit it with 320 tomorrow.
1 - 9 of 9 Posts
