I pulled my powerglide out of my chevelle to replace the torque converter. Jacked up front end, pulled off driver shaft etc. So my back end is on the ground. Front end about 14 inches up with jackstands. When I pulled the tranny, the engine fell back a little against the firewall, as the tranny is what stops the motor from moving back and forth. I have ratchet straps wrapped around the water pump and the front end of my suspension to try to get the engine at the right angle to mount tranny back up. Also it seems that in me ratcheting it tends to pull the motor off its axis(parallel to the firewall. So now i have it moving back and forth and side to side a bit.
Anyone have an easy solution for me to find the proper angle? Keep in mind I am doing this myself so having one Guy ratcheting and another under the car trying to lift and push tranny in place is not an option. THe tranny mount is in and the tranny is up far enough it is just that the motor is leaning on the firewall a little.
