replaced timing chain, put motor back together cranked on it to realize i had to have put it on wrong :drunk: anyway tore it back down fixed it. started it to hear some rattling, thought rockers were loose so readjusted them, replaced valve covers. started the motor reved it a couple times then hear ome knocking, needles to say... pulled valve covers back off to find 10 bent push rods, 1 broke. should i even try to replace and restart or should i just pull heads? will my valves most likely be bent too?
Get in, sit down, hang on
Man that sucks. :(
On the up-side though ...
You've learned something, and it will likely be a mistake that you'll never repeat.
Don't be too hard on yourself.
