I have done extensive searching on this subject both in the knowledge base, and all over the internet, to little avail.
I am more interested in seeing if it can even be done, not completele shutting off the gasoline supply, but adding a stream of propane into the intake to replace some of the amount of gasoline needed to run an engine correctly.
I forsee this only realistically possible on a MPFI/SPFI fuel injected engine that can more accurately sense A/F mixtures and reduce the injector firing time to make up for the added fuel.
This is mostly for highway cruising as an attempt to save fuel possibility.
Would a propane carburetor with reduced pressures 3-4oz compared to the standard 6 oz pressure do anything desireable if added before the throttle body?
Or do I have another wild idea that needs to actually meet reallity again?
I forgot to mention, all I really found for results on this subject were for small engines, and diesels.
