I posted this about a week ago and have made some changes but the problem still exists. Here's the setup.
Fresh 331 hemi (.030 over), SB Chevy water pump conversion, Mopar electronic ignition, large custom built (PRC) aluminum radiator (new 7 lb cap) running a fixed blade mechanical fan and shroud. The air flow is adiquate to hold a dollar bill against the air conditioning condenser so the fan and shroud are working properly. The engine has about 8.5 compression with a single Edelbrock 600 CFM carb and Isky muscle car cam.
Broke it in with no thermostat and 100% water. The engine ran fine and didn't get over 190 the entire time it was running (some 20 minutes).
Since then I installed a new 180 thermostat and changed to a 50/50 mix. The engine runs fine and takes several minutes to warm up. Once it reaches 180 however it slowly climes (over a period of 5 minutes or so) up to 220. That's where I shut it off.
I changed out the temperature sending unit (had a new one sent from the manufacturer) but that didn't solve the problem. What is puzzling is the engine does not seem to be getting that hot. I can hold on to the upper radiator hose and it barely feels warm however the intake near the thermostat is pretty warm to the touch (which I would expect). With the radiator cap off and the engine running at 220 degrees the coolant is not boiling either. Its a down flow radiator and the cap isn't located near the upper hose fitting so I can't see how much coolant is actually being circulated but I can see there is some movement.
Now here's the strange part. Once you shut it off (at 220) you would expect it to heat soak for a while before cooling off. After letting the engine sit for less than 5 minutes the temp gauge reads about 180 and when the engine is restarted it slowly works its way from 180 back up to 220 before I shut it off again. This doesn't make sense. I would expect the engine to be at or higher than 220 when being restarted especially after sitting for just a few minutes but its not. By the way this all happens sitting in the garage while the engine is idling.
Anyone out there have any ideas? Other than the possibility of a bad (brand new) thermostat, I'm stumped on this one.
Centerline
Centerline
