1 - 2 of 2 Posts
likes chevy trucks & boobies
anyone know what the B vacuum port on the front of the Q jet carbs was for ? it seems to run to somewhere in the passenger side primary venturi of the carb, or somewhere in there
thanks
Hates: Liver. Loves: Diesel
If it sources below the throttles its manifold
If it sources immediately above the throttles its ported.
Many Qjets had a higher vacuum source just below the boosters that was a venturi vacuum. It was used for multiple reasons over the years, most of them dumb :)
Some Qjets also have a positive flow source above the boosters on the secondaries that should not be confused with a vacuum source. Its a positive flow that draws warm air over the Thermostatic air door in the snout of the air cleaner.
1 - 2 of 2 Posts
