wraith
A full quarter costs at least 600.00 and you'll lose a lot of time and it'll be a lot of unnecessary work and there will be alot more chance of screwing it up.if you screw up a hundred dollar panel you can screw it up six times and gain six times the experance for the same price(win,win)..it only looks like a lot of welding,compared to all the preperation it took to get there,the welding was a breeze...as you see I followed the curve of the panel...after trying dozens of differnt ways,I've found this way to be the easiest and best plus the fastest...heres why,no measuring I start with 2" tape to rough cut it out with an air chisel (three prong panel ripper) it takes less than five minutes to tear the old one off and get inside for a better look...after I finish cut with 1 1/2" tape and SHARP hand snips I straighten the edge with hammer & dolly then grind both sides , the undercoating must come off so the flanger can work right...the best way to grind the back side is with a 4" air grinder as slow as you can get it to go,get too disks back to back be very careful you'll have the rough abrasive facing you ...this way you can grind backwards.if you dont understand I'll post a pic of it...but anyway after stepping the edge or "flanging" that little strip becomes very strong for welding especialy with the top body line so close...putting the seam any closer will create problems getting the tools in...any lower will cause unnecessary problems also... like warpage...when I finish welding and grinding you cant tell the quarter was replaced ..and thats in bare metal...both these 1/4s took two coats of ez sand putty sanded with 80 grit not bondo or 36 grit...the body work goes so fast and is in epoxy so quick its well worth taking your time...I hate useing bondo ,sanding sucks and takes patience , for me its a waste of time...when you knock on this 1/4 with your knuckle you cant tell theres anything but metal there...with bondo, filling a warped panel, no matter how nice the bondo work is... a couple of knocks will give it away,no body believes this until I show them... sooo,just like paint work...prep is everything.welding without warpage is a step by step prosess also... you dont "JUST" weld it on theres a ton of tricks that took years to learn I'll share those too. all any one has to do is ask but first theres a lot of prep work to do on the new panel with the same amount hard learned tricks and time savers
