Hey guys Im not to familiar with roller engines but I have a roller block 350 and was wondering do I need the spider in order to use a roller cam and lifters???
Thanks for any help.
Those guides are only for holding the lifters up out of the way of the cam when swapping cams. They aren't for actually guiding the lifters, the dog bones do that and the spider holds the dog bones in position. The first one isn't for the Gen 1 SBC.What about if I used roller lifters (not retro) and used lifter guides like the ones below. Do I still need a spider?
Chevrolet Performance 12595365 Chevrolet Performance Roller Lifter Kit
Chevrolet Performance 88958652
Neither of these are of any use on a Gen I roller. If you're going to install the OEM roller arraingement into a roller block that originally had a flat tappet cam you will need the OEM style lifters, the dog bones that align the OEM style lifters in pairs to the camshaft's direction of rotation, the spider that locates and keeps the dog bones engaged to the lifters, the OEM camshaft thrust plate note that there are two different center to center spacings of the thrust plate retention bolts you need to measure your block to order the correct part and correct pan head bolts to clear the cam gear. Further, the OEM roller cam takes a different timing set, this is usually a single row roller chain, there are differences between what will fit the pre 1996 Vortec and what will fit the 1996 up Vortec. There are some aftermarket twin row roller chain sets, these require a spacer or multiple gasket buildups to get the timing cover to clear the chain and gear depth. The 1996 and up Vortec uses a different and plastic timing cover than the earlier OEM roller engines, these can be interchaged with some minor effort.What about if I used roller lifters (not retro) and used lifter guides like the ones below. Do I still need a spider?
Looked into this a little more and you are right. I also read of problems when using this set up w/small base circle cams- but that's been an issue w/the dogbones too w/lobes over about 0.354".the guides in the second pic are replacing the regular dogbones.. I know i have seen this in either car craft or hotrod...
Roller WarningActually that kit made by chevrolet is all that I need. I just couldnt find a kit like that anywhere for a good price.
Thanks guys.
How much cam can those chevrolet roller lifters handle.
That's supposedly the max lobe lift w/1.5 rockers, yes. I haven't needed to use that much lobe yet w/the stock set up, so I cannot comment further except to say I would check the amount of engagement between the lifter and d-bone on any cam even approaching that amount of lobe lift just to be sure.So what u r saying is with those stock parts a .530 lift cam is as big as I should go. Which thats about where I want to be anyway on my street engine
From here:Ok can you explain rocker arms to me? What is 1.5, 1.6, 1.7 rockers and what are the differences. Are there others??? I am ging to post another thread on this to so others can comment
