question about VP Q116 fuel
3746 Views 7 Replies 5 Participants Last post by  BBCMudbogger
I have a question about VP Q116 fuel??? What adavantages does it have over C116 and I was told it was imported but I haven't found and info on that.... I was also told it was an altenative for alcohol??? Is this true. Any help would be greatly appreciated. Just an inquiring mind wanting to know and learn something
1 - 8 of 8 Posts
I'd tune for and use E85 first- there's enough in it to run a lot of boost, and that's where I believe these fuels are aimed, at least in part.
E85 is a very good priced race fuel if you ask me alittle harder to work with if your not used to it but with its high octane raiting its worth jetting the carb for it less mpg but cheaper
what is the octane rating for e 85?? and how do I find out how to work with it as far as jetting the carb and anything else I would need to know????
Octane rating from 100 to 105.
E85 is an alcohol fuel mixture that typically contains a mixture of up to 85% denatured fuel ethanol and gasoline or other hydrocarbon (HC) by volume. On an undenatured basis, the ethanol component ranges from 70% to 83%.
Hope this helps some,
Eric
what kinda carb do you have and i normaly go one to two sizes bigger on the jet size but all motors are a little diffrent i preffer holly dp they seem to run best with e85
NEW! Q16
Q16 will work well in any drag racing or circle track application -- naturally aspirated, nitrous or blowers. Q16 is highly oxygenated, requiring a 4-6% increase in fuel flow, which will make 3-5% more power than competitive 116 octane fuels. Q16's oxygenation will significantly expand the range of air/fuel ratio acceptability, so performance will be more consistent and won't vary as dramatically with altitude or density changes. For bracket racers, variations in ET from run to run will be substantially reduced. This added fuel flow also effectively increases its octane by 6-8 numbers above its standard ASTM octane rating.
Color: Yellow
Oxygenated: Yes
Motor Octane 116
Research Octane: 120+
Specific Gravity: .716 at 60° F
What are you running now? How much compression?
I run C12 at about 14:1 and don't have any issues
vpracingfuels.com there is a tuning section that has a bunch of info on Q16
1 - 8 of 8 Posts
