I talked with my cam manufac to ask question about when timing should be ocoming in on my application and I believe he said around 2500-3000 all in. I told him, right now I am all in at 1900-2000. He said if it's not pinging (which it's not) then I should be ok with it coming in a little early. My mechanic who fired the motor and set the timing thinks it's too soon and will hurt gas mileage. My cam grinder said I should have a lot of low end torque (which I do) with it coming in earlier.
Ideally, who is right. Where do I want my advance coming in at. My mechanic recommended I get a new dist. (GM HEI said good enough). Said either my current set up the springs are badly worn or weights.. but something was off with it. It had a wire on the inside that caused it not to start initially as well. Can someone recommend a good street distributor for a stock 357 with Vortec heads 10.1 compression.
