im planning on swapping my stock stamped rockers for some comp cams magnum rollers and have afew questions. 1. what are your experiences with the quality of these rockers? 2. are these rockers simply roller tipped or are they a true roller rocker? 3. would i want the 1.52 or 1.6 ratio? (the motor is a 283 bored 30 over, edelbrock performer intake, edelbrock 600cfm carb, 270 duration cam, accel pro billet distributor, flat tops, etc. the heads are off a '69 vette with 1.94 valves and 64cc chambers, (not sure of the actual casting numbers) ). im happy with the performance in general except it is a little doggy off the bottom. this motor is fresh with about 15000km on it. so should i go with 1.52 or 1.6? 4. is it necessary to replace any other part of the valvetrain when doing the rocker swap? 5. what differences will i likely notice when switching to these? decreased valve noise? more power? anything else?
thanks alot for your help.
