1 - 2 of 2 Posts
Looking to mount a US Radiator in a 1937 Olds with a Camaro clip. Rad was custom made do to pitman arm on Camaro clip. Looking mount with eight rubber isolaters which have two 5/16's threaded ends on them. Any thoughts on this or a better suggestion. Thanks. Don
Hotrodders.com moderator
Most of those use 4 two top two bottom..I am not sure of the thickness of yours but in mine I am planning on a bottom rad support with the rubber isolators and then an upper radiator support..of course mine has to be built from scratch..
Look at some stock radiator mounting methods at the local wrecking yard..Good education if nothing else..
Sam
1 - 2 of 2 Posts
