1 - 2 of 2 Posts
1969 Mustang Coupe Project Car
I'm looking to change out the Champion radiator I have for one that looks and more stock. So I have a host of questions.
1 The original radiator was a 24 inch because this was a factory air car. But with the newer Aluminum radiators can a 20 inch do the same job as the stock 24? The extra room would be a bonus for sure.
2 The original radiator has both hose connections on the passenger side. If I use the radiator with the bottom tank connection on the drivers side can the water pump pull that far? or will it create issues? i.e collapsed hoses etc.
3 I don't know if I can find one but a cross flow radiator seems like it might be an option if I can figure out the mounts. Anyone don't this on a 1969?
Thanks
Mark
Not much room for a cross flow. Brice Radiator in Gadsden, AL can make a radiator. They purchased U.S. Radiator a year ago or so and moved all the molds and stamping machines to AL. They are up and running. They will answer all your questions.
1 - 2 of 2 Posts
