Here are my latest thoughts; Feel free to correct, criticize, condemn, or augment as you see fit.
Lately, i've been constantly struggling as far as what to do about my carb situation. Even before the problem and even if i DO manage to get it back to the way it was (we are close), i knew that the carb wasn't really "right" and needed to be replaced; It's actually calibrated for 305's and 350's----and i'm running a 262 inch v-6, 4.3. While it ran "ok" for the past 41/2 years, it never really idled "right" or "normal"
(Jeg's #15005 q-jet)
In my ongoing, extensive research (and we have a lot to talk about when this is all over....), i noticed that quite a few 350's and 327's of the sixties had 2bbls----the 2G----on camaros, impalas etc. Some of these engines produced ok output------for example LF7 327---210hp, L65 350---250hp. (Note, that my goal for my engine also happens to be around 250hp, moron this later)
a) Does a 327 or 350, or in my case 262 need that much cfm if the engine is not turned higher than 5000rpm? (we are dealing with stock bottom end)
b) It seems like the REAL advantage to 4bbs is more versatility---- possibly sharper, more responsive throttle at lower rpms----due to the smaller primaries vs. the 2bbl's throttle size---they can't be too small because there's only 2 of them vs.4?
Not that a 2bbl throttle response is sloppy at low rpm. Just not as sharp, especially compared to a quadrajet due to the very small primaries.
bi) Possibly better mpg, but i don't think it would be more than 1-2 mpg if that. Plus, i don't care about 1-2mpg improvement mpg right now.
But, in terms of flat out power, would a 2bbl (assuming it flows enough) be that much slower than a 4bbl if at all?
i'm just weighing all my options, because after ruminating so much lately, i think that carb has got to go because it was never right for the engine in the first place.
i've had success with rochester 2G's before i switched to q-jets.
i define "success" as
* The engine starts and runs normally.
*The engine idles normally----without having to crank it over 1000 rpm so that it will idle in gear at 600. (and really 1000rpm in neutral isn't good either, but i'm not good with carbs, so for me it's good)
*Doesn't stall out. This is with AC and all accessories on.
* MPG is reasonably in the ball park of the stock, comparable setup: For example if a camaro, from the factory, with a 350 gets 18 mpg, and you get 16-19---SUCCESS!
i noticed that the later, large base 2g's flow around 435 cfm's. Some may flow 500cfm. If we consider a relatively stock 350 with stock or close to stock cam, spinning max 5000 rpm, the 2bbl should be adequate for airflow?
