I would like to re-clock my GM 10S1 alternator 180 degrees. I believe it is simply a matter of removing the four screws hold the case together and rotating. I did do that once but the case was not loose and did not move. Granted I did not apply a lot of pressure either. Do I need to separate the case a little bit? Or, should it rotate and I need to apply more pressure. I'm concerned about loosing the brushes or somthing letting loose then I will be back here with another question. btw, it is a new re-built that I bought and upgraded to 100 amps.
Thx in advance, r
Thx in advance, r
