hp246 is correct...It would be nice to know what's under the previous owners work ie. filler (to much, to deep, what kind), rust repair (how was it repaired, welded in patches or filled with filler or fiberglass)? So if your not sure of how it was repaired and prepared, you may be wise to take it down to metal to see for yourself...I'm not saying it was done wrong but, if you don't know, your better off to find out.
If your going to paint over top of the existing paint and primed parts, I would suggest you start off by blocking the paint and primer material that's on the car now. This will give you a good idea of how straight the car is, (the blue is fairly light in color and could hide waves in the finish, especially if your going to a darker color as a darker color will show more imperfections in the body work). I generally don't recommend sealer but, in this case a uniform coat of sealer would give you a consistent substrate color to ensure complete paint coverage.
You say your going to a darker shade of blue, is it a solid color or a metallic color? This does make a difference in the products you will be using, from sand paper to the type of paint. If the color is a solid blue (no metallic's) single stage is fine I would recommend blocking the car in 320 or 400 grit paper. If it's a metallic color, I would recommend using a base clear...(you never get the quality of shine that's desired in single stage metallic's). If you do go to base clear paint and your sealing the car, you can use the same grits for blocking as you would for single stage...if your not sealing the car, I would recommend you block the car in a 600 grit wet paper.
Hope this helps.
Ray
