1 - 7 of 7 Posts
70's Firebird or Camaro 10 bolt will fit perfectly. Only about a half inch difference in track per side.
i used a 1978 Camaro rear differential in my 1948 Chevy truck.
It fit very well as that Centerline fellow mentions
Differential/Driveline
hogghead said:
What rear end can I use for my 1951 GMC pick up I converted it to a 350 v8?
The diff that came in that truck is actually a pretty tough differential. All the Brg's are still available,but the gear sets are getting harder to find. If the gear set is in good shape and the ratio will work for you,it might not be a bad choice.
1 - 7 of 7 Posts
