In order to alleviate a severe off-idle bog, I need to replace the rear-end gear in my 1968 Camaro.
Car has a 350cid, 10:1 compression, Edelbrock Performer RPM Heads & Cam, 800cfm Carb. TH350 with a 2200 Stall converter.
Car currently has a 3.08 rear gear in a 12-Bolt Posi unit.
What would the board recommend? 3.40 or 3.73?
Well my first thought would be the 800 cfm carb on a 350! A 600-650 would probally be a better choice. I would run your combo through a dyno simulator, then through a drag simulator. How tall are your tires? I did mine not long ago and the results suprised me.
2.73 Gears
ET 12.73
Trap 109.3
0-60 4.403 sec
3.08 Gears
ET 12.657
Trap 109.7
0-60 4.397 sec
3.23 Gears
ET 12.631
Trap 110.4
0-60 4.386 sec
3.54 Gears
ET 12.581
Trap 111.9
0-60 4.344 sec
3.73 Gears
ET 12.811
Trap 112
0-60 4.719
Jordon
I have to agree with Jordan.
Heck, my BUILT 462 Buick only runs an 850 Thermoquad.
Ford 390 runs a Carter AFB 650.
Ford 351M runs an Edelbrock 600.
I'd look there first.
Can't see that gear causing a bog...
