buckhorn said:By the way, I have a Fat man rack & pinion power steering kit installed also.Greatly improved the handling. Also used there front disc brake kit.
sodas38 said:I have used a rear sway bar off a 89 Camaro on a 37 Chevy and I am currently running a front sway bar off a Mustang II in the rear of my 38. With both sway bars I had to pull the ends in to get them inside the frame rails, more so with the Mustang II. I gotta believe these could work in your frame as well. I used aftermarket links/bushings from AutoZone for the end mounts.
