:welcome: WELCOME to Hotrodders.com :welcome:ibarodder said:Whats a good width for the rear end in a 1932 Ford Roadster or 3 window ? thanks
home brew said:
sodas38 said:A good rearend for a 32 is also: 66-77 Ford Bronco
I believe the 8 inch off the MII is the narrowest of them all. I'm pretty sure its 56". Although its only four lugs.
powerrodsmike said:I thought a drawback to using the early Bronco was the 5 on 5.5 bolt pattern.
And another internet chart....
http://dfwmotorsport.com/Fairlane/9inchrearends.htm
And yes, I find discrepancies in the charts also.
Mikey
Did you use the 57 rear end as is ? Will the pumpkin be offset to the left? Or does it matter?Deuce said::welcome: WELCOME to Hotrodders.com :welcome:
As a long time 32 Ford owner ... I would say most 1932 Ford owners want a rear end that is 56 to 58 inches wide ... measured this way ...
If you want a 8 inch series Ford rear end ... the V8 Maverick is 56 inches and works great. I myself prefer the added strength of a 9 inch series Ford ... and a 57 to 59 Ford rear end is almost 58 inches wide. I have a late 60's Ford Bronco under my 32 Roadster ... it is almost 58 inches.
I have a 57 Ford rear end under my 32 3W ... it will be a full fendered car also ...
Again ... WELCOME ...
Deuce Moderator ...
ibarodder said:Picked up a 9 inch out of a Ford Granada its around 52.250 flange to flange. It has the small bearing flanges, will all the small bearing backing plates interchange ? do they all have the same axel offset ?
Have you seen a chart like this for 8" Ford rear ends?powerrodsmike said:I thought a drawback to using the early Bronco was the 5 on 5.5 bolt pattern.
Mikey
