Rebuilding a 350 into a 383 stroker. Need help on pistons and deck clearance.
The easiest way to start the rebuild is to figure the parts stack. 1/2 of the stroke, compression height of pistons, and rod length. 3.750/2=1.850 + 1.440 + 5.700= 9.010" This is what you want to cut your deck to using this kit.
Skip White Performance Detail Description This is the best price you will find anywhere! I would top the block with these ProFiler 195 cc Heads. Here is a description: SBC 23 Degree Cylinder Head, 11/32 Guides & Steel Seats
Intake Port Size: 195cc Intake Ports
Chamber Size: 72cc As Cast Chamber
Spark Plug Orientation: Straight Plug
Valve Job: 2.02/1.600 Valve Job
Assembly Options: Opt #93 Standard .650 Lift 1.437 Dual Springs, Steel Retainers, Keepers Assembled ADD $125.00
Casting Style: Standard Cooling
176 Total price $1263.72 BTW you can go a step up to the 210cc intake ports but looking at the flow charts the 195cc heads on a 383 cid engine are good up to 6500 rpm. 64cc chamber heads will give you a 10.98 c.r. and 70cc chamber heads will give you a 10.27 c.r. For the best performance and reliability a hyd. roller camshaft would be the best to use. You saved enough money on the rotating assembly to get a roller cam.
